What is your suggestion?
Airport operation decision-making system: You can see the operational situation analysis of the airport you are currently playing at and provide reasonable improvement and optimization suggestions for reference.
There will be a switch button that can be clicked to turn on, and once turned on, your airport will be in a detection state.It includes these contents:​REAL-TIME OPERATIONS
Overall pressure situation (e.g. low/medium/high). The waiting situation in the runway takeoff area (such as the number of waiting aircraft). Seat usage/availability (e.g. used/total, percentage of availability). Ground crew workload (e.g. number of flights being serviced). Usage of ground handling vehicles (e.g. number of vehicles in use). Provide ‘operational recommendations’ based on this data at the bottom.
Why is this a good idea?
Enhanced authenticity, of course, this system Suitable for you to reduce blind adjustments when playing at playable airports, it can be considered as the integration of known information.
Optional: Image or reference
