[Other] - Go-arounds in landing minigame
  • UI – for user interface suggestions
  • ATC – for aircraft control and movement features
I would like there to be the option of going around while playing the minigame. In this version, if you have an unstabilized approach, you’re simply forced to just carry on even if it means you can’t land properly, which I think should be changed.
There could perhaps be a button on a corner of the screen which would say “Go around”. When the button would be clicked, the minigame POV would be exitted, the aircraft would take off and appear again in a couple of minutes.
IRL, pilots can and sometimes do go around when conditions (f.e. the wind or visibility) don’t allow for a safe landing, or the approach is not stabilized, so adding the feature would increase realism and the playability of the minigame.
