[Other] - Improve IAD stand layout
The current stand layout at IAD is inaccurate. The stand sizes, and in some places, their layout should be changed to the accurate layout and possible sizes for realism.
The model and configuration for stands would be changed to match real life - most stands would simply allow you to unlock more or fewer sizes - some areas would need a small rework to change where stands are/add secondary stands.
The realism would vastly improve, and it would also improve gameplay! The option to use tens of E (and one F) stands in terminal C and D, plus the R stands, would greatly improve gameplay. The option in the remote stands and some others to trade out a E or other large gate for multiple smaller ones would also improve strategy.
Here is what IAD’s actual layout is - color is maximum size of aircraft can be in that gate:
You can see the vast differences, and how easily changing stands like C2 or C4 would be.
Yes, there are many airports (almost all airports before MSY), beyond IAD that need to be updated.
Other examples are LEJ (a complete revamp to cargo hub) and BKK (multi-stands for F gates and cargo terminal).
Let’s wait for a while until devs fix that… I’m sure they are aware of that…
I just hope devs can add some E and D stands to Terminal C and Terminal D, just like in reality, to serve United Airlines. Terminal B needs to add some C stands to accommodate narrow-body aircraft of other airlines. At the same time, the additional stands will provide sufficient handling crews.
As I put it in the post, official ICAO classifications:
Not too sure what each color represents?
I can figure out:
Blue=B
Green=C
I guess:
Yellow=D
Orange=E
Red=F
Is that correct?
Yeah i think so
Yes, that is correct. Sorry for not including it originally.
Hi,
let me share my player’s perspective on this topic.
I’ve been playing this airport for six years, including as an alpha test player. I welcomed the recent update and modernization of the airport, even though at one point it meant my number of active A380s dropped from 20 to just 18 due to shared gates.
If we were to fully embrace your idea of absolute realism at IAD, it would only be possible to handle 3–4 A380s at a time. Even with the option to rebuild the gates, we’d be looking at a maximum of 6 or 7 A380 stands across the entire airport — and that’s not even counting cargo.
I fly exclusively with A380s, and if such a realistic restriction were implemented, this airport would become completely unplayable and boring for me. On the contrary, I’d actually welcome more landing options for aircraft of that size at Terminals C and D as well.
I understand your enthusiasm for hyperrealism in the game, but personally, I’d prefer progress and new features over restrictions or steps backward. So I wouldn’t welcome such a change with open arms — in fact, I might even abandon IAD, where I currently have nearly 260 contracts and around 200 active A380s flying in and out.
I’m sure you can understand my passion as a player for this airport. :slightly_smiling_face:
I used Google Earth to find that the B Gates bridge can accommodate B737and CRJ. I think this option needs to be added in the subsequent game updates.
I completely agree with this
I think this is a very good idea, as the commissioning of two additional RWYs in WOA hasn’t resulted in a significant increase in capacity compared to operating with two RWYs.
19L is barely used due to a lack of parking space in Terminal D. Increasing capacity, especially for D and E stands in Terminals C and D, would better utilize the underused RWYs 19L and 19R and significantly increase the airport’s capacity in general.
However, it would also be desirable not to reduce the number of stands for handling the A388. Real life or not, the existing F stands have an exorbitant impact on the game mechanics, as many players use IAD as their main hub due to its strategic location and size (capacity).
Stand B45 is also an F stand
China Airlines flight CA 817 which arrives in IAD from PEK (Boeing 747-8), parks at stand B45 always.
Some gates can handle planes larger than their official ICAO classification. The 747-8 is only has a 3.5 meter longer wingspan than an E aircraft. If no planes park next to it (or if D/smaller aircraft are next to it) it’s perfectly safe and common.
This is very common for 757s at IAD. For example I flew on one that arrived at gate D4 (officially C class).
But the 757 in general can park almost everywhere a C plane can stand as it’s 4m wider than a 737 and around 2m wider than the MAX
That is true. I don’t really like the new class of the 757. It can park perfectly fine at some c gates. Also with the 764, it can’t really fit in some D class stands so airports have to treat it like an e plane (needs larger clearance to pushback).
It would also be amazing if the devs managed to add new concourse E as a part of a much needed IAD stand rework as it is set to open this September.
September 2026? That’s faster than I am thinking about.
It’s crazy. Every time I fly out of there the construction is much further along than I thought.
Here it is from November:
Yes, they built it quickly. Also I was at IAD last September and took some pictures.
https://www.businesstraveller.com/business-travel/washington-dulles-concourse-e-to-open-in-late-2026/
