[Other] - Round trip changes of flight numbers
  • Other – Changes in round-trip flight numbers
The flight number for round-trip will change on its own.The last digit of the arrival flight is 1, the last digit of the return flight is 2, and it becomes 1 again when coming. Set a tail number loop :counterclockwise_arrows_button:, Enable players to simulate real flight routes.
Buy a contract, for example, buy one in AmsterdamThe initial contract will provide me with a flight number KL791. This is a contract from AMS-GRU. Arrange the aircraft for this contract to land and prepare for the return flight back to AMS. When ground services are completed, the aircraft requests to slide out, and the flight number should automatically change to KL792, which is GRU-AMS.
Allow players to experience realistic route management.
Just like this
seconded
Would be a very good idea to introduce different flight numbers for inbound and outbound flights. But for the automatic change I’d suggest to make it possible to edit that as well, as some airlines don’t use different flight numbers.
Example TUI. Uses two flight numbers for most short-range flights, but the same flightnumber for multi-stop flights (mainly outside Europe).
Just a couple of examples.
Amsterdam-Zanzibar-Mombasa-Amsterdam (OR191)
Amsterdam-Boa Vista-Espargos-Amsterdam (OR3701)
Amsterdam-Willemstad-Amsterdam (OR381)
Other than that…all up for it to increase realism!
MH 2042-In
MH 2043-Out
that OR381 actually stops in AUA which is considered a round robin when it does a triangle routed flight which is why it keeps one flight number. KLM does the same with the AMS-AUA-BON-AMS flights, but that could also be a fun feature in the future
Correct. I somehow managed to mess up my text before posting. When it’s AMS-CUR-AMS it’s usually two flight numbers (OR367/368).
Nice idea will think about it
Yes , There some flight which last digit flight number is 1 and return flights is 2. Here is JFK → LAX: AAL 001
Return
| LAX → JFK: AAL 002
I could see this being possible with the split handling feature
