What is your suggestion?
Clearly describe your idea or the change you’re proposing.Featured in the #Devblog #30 Version 3.3.0 Recap and What's Next
Aircraft may already land even though the position is still occupied by another aircraft, due to delays in turnaround.
Explain how this would be implemented from a gameplay or UI perspective.If a delay occurs during aircraft handling, the player already has the option:
- if in use: assigning the position to the next aircraft scheduled in the schedule system.
- assigning the position to another aircraft
The same principle applies when delivery manager is in operation.
The aircraft are then parked temporarily in separate positions, for example at IAD in the deicing position between 1L and 1C.
However, this should generally be limited to only a few aircraft to keep the performance of the game.
Why is this a good idea?
What improvement would this bring? Better usability, realism, fun factor, accessibility?This would increase realism, especially at large airports, as delays often occur there, adding more dynamic to the game.
Optional: Image or reference
