Hi, I would like to ask what does having your own fleet give you? Do they give any special rewards or are they like any other plane?
They give you a lot more money than regular contracts, specially planes like 77W or A380. Everytime before assigning a route you can check income from a flight, in smaller planes it can be pretty low money but after unlocking some bigger planes it can be more than 4k from a flight! But remember you pay for their maintance when they are going to be in need.
Also you can send contract request to another playable airport, you can choose it as random player arrival to someone or select direct player who will receive this aircraft, so you can have contract with you friend.
If I missed something other users can add more info or correct me
Not to mention flying to a partner airport you automatically start with the max rewards.
However I should move this thread to an appropriate category as it is more less a how to play question.
Start with the max rewards,? What do You mean,?
Advantage of your own fleet is that you make way more money (Highly optimized route gives me 6,5k/trip with L plane)
if you connect with different player, you get “max rewards”. you know how normally you need 1 flight, then extension, then 2 flights and so on? if you connect directly to another player, you get the last tier automatically, therefore most sp/xp per flight
- It’s fun to build your won fleet
