PER - Perth ๐Ÿ‡ฆ๐Ÿ‡บ
Perth Airport (ICAO: YPPH / IATA: PER)
Perth, Australia
Perth is a major international and domestic airport in Western Australia, currently serving as a key connector in the Oceania region. The airport has 4 terminals (2 on each side of the runway), a large general aviation area, and is about to undergo major expansion โ€” including new terminals and a new parallel runway.
It operates over 100 aircraft stands, mainly Category C, but with 25โ€“30 stands suitable for E and F aircraft. Around 6โ€“7 are shared stands that can be split into two C bays. Most stands are remote. Additionally, there is a large general aviation sector that operates aircraft like Dash 8s, Fokkers, and Embraers using stands not included in the terminal total.
Adding Perth would fill the current C/D size airport gap between SYD and BKK. It would enhance gameplay in the Oceania region and provide more realistic routing options. Itโ€™s also an airport with interesting infrastructure, ongoing expansion, and a strong mix of commercial and general aviation operations.
Historically a base for a high number of Fokker 100 aircraft in Australia. Operates some of the worldโ€™s longest flights including:
  • Perth โ€“ London (LHR)
  • Perth โ€“ Rome
  • Perth โ€“ Paris
These would support long-haul connectivity within the WoA network.
  • Major terminal development underway
  • Shared and split stands
  • Active general aviation area
  • One of the most remote major airports, making it perfect for long-haul route dynamics
  • Strong mix of remote and terminal-adjacent stands
Perth Airport - Wikipedia
@Jonnie2604 can you make a 2D map for Perth?
May I ask why was this post closed for few days and then opened again?
When someone marks a post as being a solution (it seems anyone can do it, which is a slight issue for stuff like this) the system automatically closes it after a few days, as this is an airport suggestion someone must have noticed and flagged it so it could be reopened.
Awesome job!!!
That looks amazing
Is this the expansion plan for Perth Airport?
Yes thats correct, third runway has already begun pre construction.
New terminals should be starting construction within next year or 2
Hope the expansion gets completed soon! Then Sydney wouldnโ€™t be the โ€œlone warriorโ€ in Oceania :grinning_face_with_smiling_eyes:
How can I create a map like this of an airport???
@David you can find the tutorial (and more maps and info) here
Thx you so much :+1:
2026 draft masterplan
Ground works have commenced on the new (3rd) runway, minor works have commenced on T3 & T4, 1st of 2 multi storey car parks almost complete, airport hotel works starting soon, new terminal works to start later this year/early next year.
Latest concept designs for Perth airport.
Future qantas terminal.
