I am using Prague Airport at the moment. How do u use both runways for operations.
Playing one runway at a time is getting boring.
Short answer, you can’t. Both runways are never used together in real life due to safety
Thanks.
Even for parallel runway airports???
Each parallel airport does similar to real life. LHR for example still generally uses 1 for departure and 1for arrivals, which is very close to real life with limited exceptions
Thank you for the advice. Noted.
