I got my 2nd scraper up and running today. In a couple of days i should be:
- able to verify pax routes (scheduled) from scraper 1
- be able to extract ad hoc pax flights
- be able to extract cargo flights.
I’ve been collecting data for quite some time—so much, in fact, that Excel struggles to process it, often freezing when I try to analyze large datasets.
Despite these challenges, I successfully examined an initial dataset of 118,000 flights spanning all playable airports, including GRU. One key pattern I’ve noticed is that certain aircraft operate real-world routes with both the airline and aircraft type available in the game, yet they do not appear as selectable options for those routes in-game.
With the latest update, I can now better target in-game destinations, allowing me to create a more precise and accurate flight schedule. Below is a refined list of real-world routes featuring playable airlines and aircraft:
| Origin | Destination | Airline | Aircraft |
| GRU | ACC | Ethiopian | B772F |
| GRU | ADD | Ethiopian | B77L |
| GRU | AMS | KLM | B773 |
| GRU | ATL | Delta | A333 |
| GRU | ATL | Delta | A359 |
| GRU | AUA | Gol | B38M |
| GRU | BOG | Avianca | A20N |
| GRU | BOG | Avianca | B788 |
| GRU | BOG | Latam Chile | A320 |
| GRU | CDG | Air France | A359 |
| GRU | CDG | Air France | B773 |
| GRU | CDG | Latam Chile | B789 |
| GRU | CMN | Royal Air Maroc | B789 |
| GRU | DFW | American | B789 |
| GRU | DOH | Qatar Airways | B77L |
| GRU | DXB | Emirates | A388 |
| GRU | EWR | United | B772 |
| GRU | FCO | ITA Airways | A339 |
| GRU | FCO | ITA Airways | A359 |
| GRU | FRA | Latam Chile | B773 |
| GRU | FRA | Lufthansa | B748 |
| GRU | GIG | Latam Chile | A20N |
| GRU | GIG | Latam Chile | A21N |
| GRU | GIG | Gol | B38M |
| GRU | GIG | Gol | B737 |
| GRU | GIG | Gol | B738 |
| GRU | IAD | United | B764 |
| GRU | IAH | United | B789 |
| GRU | IST | Turkish Airlines | A359 |
| GRU | JFK | American | B789 |
| GRU | JFK | Delta | A339 |
| GRU | JFK | Latam Chile | B789 |
| GRU | JNB | Latam Chile | B789 |
| GRU | JNB | South African | A333 |
| GRU | LAX | Latam Chile | B789 |
| GRU | LGG | Ethiopian | B772F |
| GRU | LHR | British Airways | A35K |
| GRU | LHR | Latam Chile | B773 |
| GRU | LIS | Latam Chile | B773 |
| GRU | LIS | TAP | A339 |
| GRU | MAD | Air China | B789 |
| GRU | MAD | Iberia | A332 |
| GRU | MAD | Iberia | A359 |
| GRU | MAD | Latam Chile | B789 |
| GRU | MAD | Air Europa | B789 |
| GRU | MCO | Latam Chile | B789 |
| GRU | MEX | Aeromexico | B789 |
| GRU | MEX | Latam Chile | B789 |
| GRU | MIA | American | B773 |
| GRU | MIA | American | B788 |
| GRU | MIA | Atlas Air | B748 |
| GRU | MIA | Latam Chile | B773 |
| GRU | MIA | Latam Chile | B789 |
| GRU | MXP | Latam Chile | B773 |
| GRU | OPO | TAP | A339 |
| GRU | ORD | United | B78X |
| GRU | PTY | Copa Airlines | B39M |
| GRU | PUJ | Arajet | B38M |
| GRU | PUJ | Gol | B38M |
| GRU | SCL | Latam Chile | A320 |
| GRU | SCL | Latam Chile | A321 |
| GRU | SCL | Latam Chile | B789 |
| GRU | SCL | Turkish Airlines | A359 |
| GRU | SCL | Sky Airline | A20N |
| GRU | SCL | Latam Cargo | B763 |
| GRU | SCL | Latam Cargo | B763F |
| GRU | SJO | Gol | B38M |
| GRU | YUL | Air Canada | B789 |
| GRU | YYZ | Air Canada | B789 |
| GRU | ZRH | Swiss | B773 |
Not to duplicate any efforts, but is there any gaps or missing data from my list that you might have found?
I am more focused on flights that are less scheduled and lean more toward the cargo and charter side of aviation.
Its better to seperating B77W and B773 since korean ANA and cathay operates both
At first, when I was working with Excel, a lot of data was lost during extraction. Processing adjustments was slow and inefficient—Excel took nearly an hour to calculate a single workbook, and I had five of them.
Since switching to SQL, everything runs much faster and smoother. Now, as long as my conversion tables are correct, I can process all the data in just a minute. Currently, I filter by aircraft type, but my goal is to create a system that automatically converts aircraft registrations into their corresponding types.
Hey can You help me to find any airport from IAD with B762,? Becoz i can’t find any… i have 4 B762, and its useless for me..
You mean player aircraft? This is a thread for realistic flight routes, meaning mirroring real life operations. According to my list, only B763s and B764s regularly fly to and from IAD. This is almost exclusively United on European routes. There’s also some domestic B763 cargo traffic. If you wanted to make realistic routes for your player owned fleet, any destinations utilizing B752s, B763s and A332s/A333s would probably work if your B762s can reach.
I came across some data suggesting that Austrian Airlines also uses the B763.
Also, FedEx looks to be the only one running the B763F on the IAD route.
It’s a bit of a bummer that more B767 routes aren’t in the game. DHL flies the B763F all over Europe on shorter routes, but in World of Airports the biggest freighter you can pick for those is the B738F. Same deal in Japan—ANA and JAL fly the B763 on domestic routes all the time, but those aren’t in the game either.
Note: Any airlines not currently in World of Airports are automatically filtered out by the SQL script, so they don’t show up in the data.
I’m strongly considering doing a playable airport with strictly realistic flight routes. Which airport(s) might be the most fun to do that with, and why?
I would say maybe lhr due to the crazy variety of routes and airlines, although iAd could be also. For detailed lists of every real life operation, you can check the wiki, they tend to be there
I’ve completed INN and BRI with strictly realistic flight routes and its pretty fun. LHR is my favorite though and its fun to look up what terminals each airline is in and only let them go to the correct terminals.
BKK isn’t too shabby either doing realistic. There’s SO many flights, and even cargo too. I’m running out of room and time with contracts and I’m maybe 1/2 to 2/3 of the way through gathering them. And that’s only doing one or two of the models that fly in per contracts vs all the possible variations.
if Anybody has questions for SYD just ask cause im playing it a bunch and playing it with realistic flights!
I find myself having to let Qantas use some of Jetstar’s gates, and Jetstar use some of Virgin Aussie’s gates because having just a fraction of the actual flights IRL doesn’t translate into the game as far as scheduling lol… that and those pesky A/B only gates that still need to be fixed to handle C.
I too have to do the same thing generally speaking some Qantas and QantasL in the. Jetstar terminal and some jetstar things in the virgin slots. But yes those pesky three spots in the Jetstar wing need to be C and the parking spot between jetstar and Qantas need to be A/B or hopefully some Cs
If you mean these
Also saw that this is an issue now
Andas someone whole plays mostly realistic it really bothers me, cause why?
I too scrapped every non real flight into sydney and now im doing realistic flights, and yes this parking configuration is really anoyiong me
Well the stands at the national terminal are also like that, only b when it should be c
Same here, I’ve switched to only realistic flights too.
