Hi All,
I’m undecided on what plane I should for. I’m not sure if i should go for the new A340-500 or B747-100.
I currently have the below:
- AT46
- CRJ9
- A21NY
- C919
- E190
- B752
- A333
- A343
- A35K
- A388
- B748
- B734F
- MD11F
Thanks ![]()
Hi All,
Thanks ![]()
I would go for B77W one of the most profitable/cost effective planes
Funnily enough I was actually in a very similar dilemma not too long ago, choosing between the A345 and 747SP.
As for my insights, let’s be honest, neither is very profitable so you’ll mostly be getting them because they are interesting planes rather than anything else, so if you have one of the two which you like more then just go with that one.
If you do want to go at least kind of based on operations, the A345 could be better because it has a longer range than any other plane you currently have (I think) so it could unlock some new routes for you.
Also, if you really are undecided, you can make a poll in this thread like I did multiple times and let others decide for you ![]()
I personally would go with the A345 also, because it has 146 XP at level 10. That is not the highest xp by a long shot of any aircraft, but it is more than any other aircraft of yours except the A388 and MD-11F, while also having excellent range.
