Red collision light position issue (top of aircraft B777/ B787)
Platform:Android
Device:Samsung S23U
Game Version:3.2.1
Airport: Airports that can be reached by all E-class aircraft except INN.
The red anti-collision light (on the top of the aircraft) of All B777 models located too close to the L2 door .That position is the location of the antenna package .It is incorrect. It should be located at the front. Approaching the L1 door :door:
Similarly, the B789/78X red anti-collision light is also placed incorrectly in the current game position.
:wrench:Fine tune ahead,Fine tune to the front and place it roughly in the correct position. B777 The red anti-collision lights on the top of the aircraft should be located near the L1 door, and the same applies to its B772/773/77W/77LF.
B789/78X:Approaching L1door
B77W:As can be clearly seen from the figure,It can be clearly seen from the figure that the position of the red anti-collision light is too close to L2, :check_mark: It should be closer to L1.
Screen_Recording_20250907_213821_World of Airports(1)
B777-200LR Too close to L2, should be close to L1 above the letter ‘M’.
Screen_Recording_20250907_170650_World of Airports(1)
B777-F (Taking China Southern Airlines 777F as an example, the position of the red anti-collision light should be above the “方”.)
Screen_Recording_20250907_171425_World of Airports(1)
B789:The top red anti-collision light is also close to the L1 door, taking Xiamen Airlines B789 as an example
It should be located on the logo of the egret
Screen_Recording_20250907_171212_World of Airports(1)
B78X: The red anti-collision lights at the top of the game are all behind the L2 door, which is incorrect. They should be in front of L2 and approaching L1. “H”:top_arrow:
Screen_Recording_20250907_212634_World of Airports(1)
Additional Notes:
the GIF is from a 77W just so you know
I made a mistake in my haste and corrected it
No problem :smiley:
I created internal task to get it changed.
