Scroll wheel is useless
Platform:
PC play games
Game Version:
3.4.1
Airport:
Yes
The mouse scroll wheel does basically nothing. Zooming seems to be something you can’t do in any view, and scrolling the airport or aircraft lists is slower than just clicking and dragging.
cannot post videos on this forum + it’s really hard to show something like this, actually
Additional Notes:
Probably an oversight before the game was allowed on pc
The zooming definetly needs some work on the mouse yes. I sorta found a way to scroll, but its not really worth. What i mean is that you can click on planes to zoom in, and click on the 2d map to reset.
try holding CTRL while scrolling, this is how it works on Bluestacks
same problem
Tried that, shift, and alt, no luck
I realise this is not really on topic, but maybe we’ll get some love when they fix on PC. Running the iOS app on MacOS (which is possible without emulator) also has no zoom. Not on mouse, not with keys.
I found a workaround for zooming in the PC version. Basically, you need to emulate a pinch gesture.
To do that, add a new on-screen button from the left side panel (press Shift + Tab to make it appear in full-screen mode).
Position this button along the edge of the game window so it doesn’t interfere with the on-screen controls (I placed mine at the bottom center). Then resize it to the minimum (optional) and assign a convenient button to it (I chose the right mouse button).
After that, you’ll be able to zoom in and out by holding the left mouse button together with the button you assigned, and moving your mouse up and down (or left and right if you placed the on-screen button on the side of the game window).
You can also rotate the default free view with this combination. Just move your mouse horizontally while holding the buttons.
so, they technically fixed this in 3.5.0, but it only affects to zoom, and not the airport/plane lists, so while it’s “fixed” it’s not really as I would expect it still
