Bug Report Template
Platform:
iOS26.3.1
Game Version:
V3.4.1
Airport:
LHR,SXM
If there is a sliding scheduling problem, it will be unable to move.
I hope there will be an operation instruction to control the advance movement of one of the aircraft in this case, or to change the taxiing path and stop waiting in other place.
When a plane goes out and a bunch of planes are about to enter, they will let the planes go to each other, which is very easy to appear. A plane is waiting for take off on the runway. When a plane lands, the runway exit is blocked in a queue waiting for the plane. If the plane can’t leave, the runway plane can’t take off. This will also get stuck, especially in small airports with a single take-off and landing.
Additional Notes:
After more flights, this problem will also occur after the control operation of the automatic aviation tower, which cannot be improved. The main reason is that after the stuck death, it is impossible to manually issue instructions to move the aircraft to avoid, or change the exit of the runway
Before posting, please make sure the bug hasn’t already been reported by someone else.
