[UI] - Cinematic Camera Features
better camera elements. The devs have access to cinematic options and all, but we can’t use them. I propose to fix that to enable far better shot for content creators and better views for players: imagine having your camera moving slowly around the whole airport! Also, give freecam true freecam abilities, not the restricted way it is now.
there would be a better freecam with 360 degree rotation, no preset angles (unless the devs can find a way that is more compact than the current method of displaying them), and a cinematic mode. This might require a pretty serious setup method, like setting start/end points or keyframes, and a track. Tilt would have to be considered too, which would probably mean that the cinematic mode would be its own screen, with all other ui elements removed, kind of like how the spotting cameras remove all other ui bits. Then you could screen record.
one of the core parts of the WoA experience is its graphics, and to have such a small and restricted set of views seriously reduces the enjoyment of those graphics.
the WoA official YT channel provides many great examples of this.
Another example of this: the most recent short, aerolineas argentinas, is not possible to film by players because it requires you to leave the aircraft perspective to assign handling crew.
