[UI] - Realistic Jet bridge connection
I have noticed that the jet bridges for all airports(i assume)were off when they connect – they don’t fully connect to the aircraft. I would suggest that you can like animate the connection of the jet bridges to fully connect the aircraft. I know this could take a while to fix every jetbridges but just take your time to fix the jet bridge.
an example of how it looks like in real life:
an example of how it looks like in WoA:
Share your thoughts!
Hopefully there will be a possibility to have jetbridges added to the second door for D-F planes
Or maybe you can choose as it’s not possible for second door on certain 767 operators like DAL
The hole of the jet bridge connected to the plane is a small hole.
