Which of these aircraft should I save up for? > B777W, A350K, B748 or B789
My current aircraft selection is > ( already owned and bought )
- DHC6
- ATR76
- DH8B
- E170
- B734
- F100
- A21NY
- B764
FYI the backbone of my current fleet is the A21NY
I’m not good at telling you the best, but the coolest, Fokker 100
I already own all the aircraft listed below the E sized aircraft i mentioned. but yeah the fokker 100 is a killer aicraft
How much GP is the B748? (It’s F size, btw)
You should consider the A388 as it’s price will eventually increase, same for the B748 if it hasn’t already.
That said, between the ones you listed, the A350K is a popular choice for leveling airports, while the B789 is also a solid choice for lower demand airports.
I’d recommend, in this order: A388 > B748F > A35K. If order is swapped in any way it’s also okay.
@FocusedDictum70 you are right the B748 is an F size.
I’ll go for the A350K since that would be good. Hopefully the Devs add the A350ULR so i could get that instead. that would make flights be much more better. anyway thanks for the helps fellas
Just a heads up, even the A332 and A333 is getting remodelled and it’s prices will go up too, in case you would like all aircrafts in your fleet, I would say A332 and A333 first (even before A388 as A388 remodel isn’t confirmed)
But if you are profit oriented go for the A388
I was thinking about getting the A333 , Also anybody realise theres a such thing as the A339!!!
Also can someone help me, I am trying to get my B764 to get more money between SYD and HKG but at the current moment my A21NY is doing much better than that.
Actually, at maximum distances, you get more net profitability from A21NY compared to B764.
It is one of the better selling wide bodies of the modern era, yes.
I’d actually recommend the B78X for E class. It doesn’t have the range of the A35K, but income is better. If you’re willing to buy the B77W then you might as well go for the B748. But obviously costs will be higher.
