What is better?
Should I continue with Class A and B aircraft contracts, or should I cancel them and get contracts for larger aircraft? I have about 15 contracts for smaller aircraft in total. What do you recommend I do? This is at SXM airport.
It’s up to you, if you want to level up quickly, bigger is better, though at SXM you’re limited on the sizes you can operate. If you like to roll with a smaller airport then keep going with the A and B class. My INN is all B’s & C’s because none of the D’s are realistic.
If you don’t have them already, I recommend getting lots of E170/E175 and F70 contracts. They are B-class planes but they don’t have to backtrack, and that saves you a lot of time. I think those are optimal for SXM but you should definitely have a few larger planes/contracts too
