Nice tutorial, well explained
Some updated to above introduced (due to user interface changes).
Some updates above, Connections explanation added.
@RudiMentaer75 @DuneCrawler you guys are the most frequent people i see on the forum what do you think? The account @alahiru is linking some bs site full of ads on topics that are tutorials for the game. Plus its linking tutorials which could confuse a bunch of new players. I think its a bot. What do you think? Do we contact shill?
I am looking on it already looks suspicious a bit
like self advertisements. Posts with junk websites will be deleted if that does not help users will be blocked.
There are many active players on forum that can help / answer questions (which is nice gesture towards me simply because its just to many some days and players know game very well).
I guess I am to late…
Really helpful guide. And a very nice game too. I like it. Unfortunately the “random connection” feature never works properly. Needs repair.
Yeah its not the best we have already complained. If you need conections make a post in the #connections-requests category
OK, thnx
If you turn that button on, then the taking off planes will be marked in a green outline. When turned that off, no green outline will be there.
Does anyone know, or have you figured out, how to determine which destinations are the most profitable? I thought longer hauls would bring more money but that’s not really true. I have a 1700nm haul that makes less money per plane than a 980nm with similar planes. Just wondering if there is some method to figuring this out. I’d rather spend my keys on money making hauls and leave the less profitable ones for later (or not at all). Anyone?
As we’ve all found out the shorter the route the more profit is to be made, the longer the route the bigger the loss. I’ve found every long haul connection is a big loss maker, for example sticking an A380 on the IAD-NGO route that aircraft by the time it gets to maintenance D will have lost 100000W (in fact even more as I didn’t factor in the fuel, just the straight fee). So keeping IAD as an example, I’ll send a maximum of 4 heavies to each connection & the rest of the fleet on short trips to support them. So I end up with the mad situation of A380s & 747s going to MIA & MEM & all the Ls going to places like MEM, ATL, MSY etc. There is more money to be made with the cargo but the jumbo takes ages to load & there are only so many slots for them. NGO is harder to make money for me so I’m selling a load of the pax aircraft & buying B777Fs to support the connections. I don’t know how else to make a profit now the system has changed
And what about classic normal planes. The longer the route, the more the profit?
Hello dear ones,
I just downloaded this game today and I have to say that I really like it! But I have a question. Do I have to refuel the planes every time? Or are any options wich I can let away? I mean if I have to press all the funktions in the “handling” menu? Or only some of these.
Thank you very much in advance,
Kevin
In a S-tier plane, you have to give bus, baggage and fueling. After handling with buses is done, you have to bring the cleaning car. Within cleaning, baggage will be done unloading and you have to give another baggage for loading. After cleaning, you have to give the bus for boarding and after its done, you can press the takeoff button.
In a M-tier plane, you have to give a bus or gate bridge(Every airport has M-gates except INN), baggage, fueling, water and lavatory. After deboarding with passengers is done, you have to give cleaning and catering and within handling baggage will be done unloading, you have to give another baggage for loading. After handling cleaning and catering, you have to give bus or have to press boarding for passengers. After boarding you can press takeoff. (I don’t know if there are stair gates for M-tier planes and sometimes baggage takes more time than boarding in gate bridges because gate bridges boarding goes faster than stairs)
In a X/L-tier, you have to give all the same but catering in X-tier planes takes longer than cleaning so it also has to finish for boarding. These planes need cargo bay’s instead of baggage.
At INN- only S/M-tier planes
At BRI- only S/M/L-tier planes
At PRG, IAD, NGO, SAN- all S/M/L/X-tiers
Thank you so much for your quick and informative response!
Greetings
Well, it worked pretty good for me at PRG. Now I should specify it’s a connection to INN and BRI which aren’t that far so I can service 5 planes from BRI and 5 planes from INN per day. The achievement is coming along quite quickly.
Muchas gracias, echaba de menos un sitio donde se explicase como se juega
