So I am about to build a fleet but don’t know any plane to choose, any ideas?
- crj2
- any ATR aircraft
- sf34
- ATR cargo aircraft
Save up for a 737
or maybe if you want a B-class plane specifically the F70 is a great one to consider
I might do f70
I think you should get some A321NYs their profit is quite good
It’s hard for me to honestly recommend any of these planes for fleet construction. These B planes just don’t have the range to be used across player airports outside of Europe. Now if you don’t care about player connections, then all of the ones you mention have pros and cons.
I’d echo the above A21NY as a good starting point. It’s the only C plane that can make player connections from every playable airport and makes excellent profit, SP, and XP relative to its size class. Another option is the A19N, which underperforms in terms of range, profit, SP, and XP, but its lower capacity is useful for some of the lower capacity routes especially in continental Europe.
If you’re set on class B planes here are my recommendations (in no particular order):
CRJX - most profitable in terms of all currencies and excellent range for its size, but this plane backtracks at INN, CNN, and SXM which is a major downside for me.
E175 - this is the most profitable in terms of B class planes that don’t backtrack
F70/E145 - these are planes that I like to talk about together. F70s have a bit more range, but the E145 has lower capacity which opens some routes for AI airports. The latter also has better Wollars profitability, but the former wins in SP earnings.
Most importantly though… fly the planes you like. It’s way more fun!
Hope that gives you some food for thought. Cheers!
I followed CJ’s advice from an earlier post of his when I was lurking about the forums. Now I have a growing fleet of E175 at SXM that is making good wollars and SPs with no backtracks and easy handling. Zip in and zip out. If you plan on any fleet at SXM, E175s are great.
They have range from ONLY Europe, i am getting golden airplanes, and also I am changing my IGN name as well once I get them.
The thing is, with 10 golden airplanes, I can’t get an single Airbus, you know.
Also, I am starting a small optimized B class fleet, that’s why those options are there.
I’ve come back to the game, should I get and grind up Zurich?
Thanks for the votes, I made my descision of ATR aircraft and ATR cargo.
I’ve grinded a lot at ZRH Airport (Level 48) and got up to 70 GP. Now my question, jow should I spend them?
I would be curious how other players think about that.
Save them until the next airport. Prob for GP at said airport
If you haven’t got the A380 or the 737 family get it as its being remodeled now.
If you’re having trouble deciding which one to choose, I’d recommend the A380 if the unlocked aircraft is small, and the B737 series if it’s large. However, once the update is complete, both will require a significant number of Gold Airplanes, so if you have the resources, it might be a good idea to unlock both!
I don’t think buying airports with gold really make sense because you can get them for free just by levelling. The next airport is not coming for a while either, most likely around Christmas so you’ll probably have enough time to save more for that if you wanted it, but if you already have ZRH at a high level then you can get it easily from that for free. For the ZRH premium pass, I also wouldn’t get it if you’re this far already, the passes are most important in the beginnings of an airport and the ZRH pass specifically seems less worth the gold than others. PRG premium pass is cheap and not bad, but usually premium passes don’t increase in price after a remodel so you can always keep that for later. Now I’ll definitely echo others in saying get 737s since they are very cheap and if you already have those then go for the A380 ![]()
