I mean, to some extent it is simply how it operates in real life. Beyond that, there is the option to operate A-class aircraft in your own fleet, so there is some use for them.
Obligatory âJetstream whenâ comment
Iâm assuming you mean Purolator and not Percolator haha. Theyâve had some cool planes in their fleet over the years and would make a great addition to YVR!
Itâs been around since 2.something I think
It was there before the Max variant was even painted
And I guess itâs been kept like a bit of nostalgia
Which is why I made a post suggestion a downgrade of class for the SF34
In real life itâs a B class but itâs handling fits those Stands at the south terminal perfectly as an A class
And its wingspan is about 21m whereas the DHC6 is about 19m and the L410 is about 20m (Both classified in the game as A class but IRL are both B class planes)
Back when it was in the context of SXM, I was skeptical of this. Now I feel like making the Saabs an A-class is 100% a must do.
Is anyone else struggling with the tower not crossing cargo planes across RWY 8R when all four tower managers are enabled? I have to pause approach and departure for them to actually cross, which is a bit annoying.
do someone have the img showing all the runway and taxi path?
I remember!
Welcome to the dark side ![]()
A few little edits for myself but I really think stands 32-38 donât need to overlap at YVR
using the E175LR due to itâs wingspan primarily, however close to each other, I still argue looks nice to have them all parked next to each other
This along with maybe making the SF34 an A-class plane will definitely enhance stand optimization at YVR
And in this video youâll see after the 11:57 mark how all the Dash 8âs are just parked next to each other
Yes, on top of that, it blocks way of other cargo plans taxiing to the aprons
Yes, that can be a use case. But there has been no precedent or similar scenario at any other airport. For shared stands, the aiport did have that specific clasa contracts available
I noticed that a few line markings near concourse extension D (imaged attached), which suggest shared stands, but no stands are currently assigned to them. It is different from the maintenance stands that have no markings on them. Any idea about it?, could it be stand display missint?
These are de-icing stands, used in summer as dumping grounds for aircraft awaiting a gate or being sat to one side. Theyâre never used for loading and unloading.
Air North has been eliminated Has Air North been removed from Ottawa when it was previously listed, or is this a mistake?
GREAT spot from you!!!
Finally after 3 days
Would love some of those mints were regular contracts
Like the DHC8 and E190
