YVR - Conversation
Basically every toothpaste that was added in the update should’ve been a regular contract. Especially because the dash 8 is still flying. But oh well​:smiling_face_with_tear:. Trust the devs plan I guess…
Does anyone know what the destinations are for the reward airline contracts?
A question for those familiar with YVR: is this terminal operational? I was checking Flightradar24 and don’t see any flights arriving at or departing from there.
Is this a combined terminal? Do domestic flights arrive here?
No apparently it’s only international
Need to move the baggage trolleys as it’s glitching with activity baggage trolleys.
I would only assume that the 1st image is de-icing stands but i wonder if the devs implmented that here since we have decicing before they leave the gate??
I noticed you cannot park Cat D planes all next to each other on the eastern Cargo (FedEx) Apron. This could also easily be fixed as FedEx only flies 757s and 767s to YVR, and this clearly works without issues IRL.
What if you do the two at the sides? What does it leave the middle.
I can do two Cat Ds on the side ones, the middle is B only then
This is because IRL the 757-200 is small enough to use C sized stands
It’s the same thing with LEJ
It dont for me make sense why i should buy 51 or 52 when it Block there a and b. When i buy the a and b it block only whole number
I didn’t unlock these yet but I thought 51/52 would be C stands
Would be interesting to see how it works out
Yes, same issue i highlighted earlier and on top of that, we don’t have any A grade contracts available for both cargo and passenger planes.
And i have never seen it in any other airport, where you don’t have a contract type that seems to be the only way for shared stands to make sense (A grade in this case). Hope the SFB planes are made as A level, i feel they might fit in the space
Similary check out the south terminal too!
what’s wrong?
I had an aircraft well one of mine actually taxi onto runway when another aircraft was taking off.
It happened to me too with a C-lass departing with a B-class
Same question here… Can somebody please add these here or update them in the sheet? Thanks :smiley:
