YVR - Conversation
Do any of you guys missing the walk path on gate 23 ?
We’ll get to it. Been a bit hectic trying to keep on top of things atm.
I’m sharing the materials posted on Discord.
Thankyou, I really need those :grinning_face_with_smiling_eyes: :+1:
Dear developers, Could you please enable aircraft to take off from both runways at Vancouver Airport? Currently, planes only use one runway, which causes excessive congestion—and, frankly, it’s quite annoying. In reality, aircraft use both runways for takeoffs. Please address this as a matter of urgency.
This only applies to take-offs; please include it for both runways.
Same issue as BKK, the crossing point is too far down the runway that planes get to the take off point before the airborne plane passes the crossing point. It may be “fixed” if crosses are allowed once planes are airborne, planes can still line up but the crosses will block taking off immediately.
IDK if this is completely true
I don’t know YVR very well but I’ve been monitoring it since the release in the game
And apart for some exceptions, all landings are on 8L while departures are 8R
there are more landings on 8R than takeoffs on 8L
And this is definitely a personal opinion but I see a lot of y’all congest the queues by handling everything super fast and at the same time. That of course will stagnate the flow at airports especially with 1-2 runways. That’s not the devs fault cause I see and believe most players are only trying to speed run to level out the airports instead of actually enjoying the gameplay. I know every has their own playing style but that’s the result
*just My two cents (bring on the rebuttals :rofl:)
Those are the West Pads. We use them for Deicing year round however they’re dedicated for deicing between mid October to mid April. Outside that time frame they’re used for international cargo flights, VIP aircraft and to park planes on. Before covid international flights would park there for RSO operations. That’s mainly for the front pads W1-W9, the back pads (next to the ops building) are only for parking, cargo and VIP. Deicing only happens there if the front pads are somehow unusable.
Is it just me or has porter airlines been removed from most airport? I could have sworn that before the 3.8.0 update it was availible at more that toronto and ottawa…
Dual runway departures is quite rare at YVR and as such in reality there is usually a lot of congestion during the peak times z
BTW is the runway config locked into 08L/R by devs or YVR was operating under that config for days or that’s the dominant operation? I only had once using 26L/R after YVR was available.
I could’ve sworn Hamilton has porter flights but there are some stuff still missing even before 3.8.1
Like WJA Q400 flights from Victoria and Nanaimo
Which is weird cause ACA does have Q400 flights
I think the latter
I’m new to the forum so I’m not quite sure how everything works here but YVR is my home airport and I work there as well. I was ecstatic to see that it was added and the detail is quite amazing but after playing I have some insights to make it more realistic.
Stand 802 can handle an A332F
Gates 15, 20 and 48 are all E level gates have had 789/A330 use them constantly
E1-E3 are also E level gates usually used for parking or VIP
Nearly everything that parks south (some A/B gates stuff, cargo and south terminal) lands on 08R/26L
Not sure if it’s possible to make this happen but the cargo stuff doesn’t cross the threshold of 26L for a 08L departure. They’ll taxi back up Delta and then go H, L.
Nothing taxis through the west pads. It would be nice if stands up to a E level could be added for W2, W5 and W8. As well as F level stands at W12 and W15.
I notice the A only stands as well at a few cargo ramp (FedEx and UPS) those are used for C208 and 1900F feeder aircraft but seeing as their not in the game I’m hoping those come. The only A contract that would make sense would be a Harbour Air DHC-6. They have wheel service to YYJ.
That’s not what I meant—believe me, I’m enjoying the game to the fullest! I do keep the aircraft at the gates for longer, but because the turnaround times are so short, they’re ready again in no time and head off toward the runway. Perhaps it would make sense to extend the turnaround times? My only issue is that the aircraft end up backing up all the way into the apron area. Seeing that visually just isn’t fun for me at the moment. Sure, some congestion is fine, but not to the extent we’re seeing now. :wink::wink:
I think it would be a big help to adjust the turnaround times for the aircraft. Currently, small aircraft (categories A–B) stay at the gate for a maximum of 3–4 minutes; category C aircraft, I believe, stay for 11 minutes; and larger aircraft for 20–30 minutes. For the larger aircraft, the current turnaround times are acceptable, though they could even be increased to 40–50 minutes. In my opinion, the small aircraft (A–B) should spend at least 20 minutes at the gate. What do you all think? It probably all sounds very complicated, but that’s just my current line of thinking! :wink::grin:
I don’t know, but when I watch YouTube videos by plane spotters, I see aircraft taking off and landing on both runways :person_shrugging:
I’m not saying it doesn’t ever happen but 08L/26R departures are very uncommon because of noise abatement.
If I recall correctly, a dev blog once mentioned that the ground service vehicles were going to be reworked, which would also change the turnaround times for aircraft—meaning planes would end up spending more time at the gate. Unfortunately, there hasn’t been any further word on that since. Does anyone know anything about this, or what the current status is?
