[ATC] - Reconstruct the delivery control interface
Reconstruct the delivery control interface and hand over the current interface to the ground control interface. Because this is their responsibility.
Like outside, open itLike outside, activate and trigger the delivery control interface.After setting it up, check the effect on the game’s main interface.
The specific framework is as follows
The actual performance in the main interface is the effect of this suggestion
https://forum.worldofairports.com/t/atc-delivery-apply-for-release-instruction/33254, and the preliminary work is the framework above.
Delivery control, as an indispensable part of ATC, can be truly experienced by players with the continuous improvement and optimization of the game.
â‘ Simplified versionIn the simplified version, some algorithm links need to be modified, such as changing the allocation of aircraft positions to set the priority of aircraft clearance.
Detailed construction
Like a flight schedule,Set up a window that can automatically generate release instructions for players to operate as needed.
