Hi everyone,
I’ve decided to operate LHR again, mainly for connections. If anyone is interested, I currently have the following aircraft available:
3× A380, A359, 2× B789, B788, CONIC, B77WF, 2× A306, A332, 2× A320, 3× A332F, A333, B748F, 3× B752, B738, B752F, B78X, and A35K.
Most of these aircraft can reach all airports. Please reply with your username, airport, and the aircraft type you’d like me to send.
I’m usually active twice per day.
Want a load of COMACs? I’ll be getting quite a few of those for connections at my PRG and a couple at BRI as well
Anyways, I’d be happy to take the narrowbodies at my PRG and you already know about my other hubs
Yes, that works for me
I’m happy to take COMACs for connections. In return i will be sending the narrow bodies
Sent the first 5 of them, I’ll get more in the next few days
I can take your planes at my GRU. IGN: Air Nome. I play daily
I’ve sent all the narrowbodies. If you’d like widebodies, I can send those as well, and I can still take COMACs for connections
Done, I sent 788 and 2x 789
Update,
All my narrow bodies and some of wide bodies have been assigned. The remaining:
B752F, 3x B752, 3x A332F, 2xA306, A332, A333.
Thank you
You can send me as many as you like, if you still have any available airplanes. I can send you, too, just like SYD.
Happy flying.
Great, where do you want them?
Please send them to my HKG
330’s can’t reach HKG or BKK. It’s either MCT or IAD the distance is too far for the aircraft.
Hi everyone,
Most of the aircrafts are gone. The remaining 3xA346, A332 and A333. They can reach MCT or IAD.
Thank you
There’s 5 more C919s for you, and a 757 I didn’t know what to do with
If you get anything that can reach BRI I’can take some planes there, I’m trying to get that airport leveled up now
Do you have any of the freighters available? I’m looking for any cargo aircraft to my LEJ as it’s the only airport I’ve never maxed in 5 years of playing this game and I’m trying to get there by the end of February.
IGN: CJRVWilliams420
Edit: Just saw the message above of what you had left. Should’ve scrolled up more!
I can buy 346 for one time and send it to you. But i have no clue if its reach BRI from SYD or not. In LHR I have 2 levels remaining for max so i can take COMAC’s and 757 if u want to send them in LHR.
Probably won’t reach, and even if it does, the A346’s economics are trash so it wouldn’t be profitable…
First E type to be unlocked by my fleet. I’m planning to unlock another E for pax but idk which brings good rewards. I just bought 77L for first cargo
Depends on what you’re looking for, the 747s get you most rewards, but they are expensive and take a while (and a lot of handling crew) to turn around. The 777 is really great too, taking only 10 handling crew for similar earnings to the 747s. If you want a smaller E-class plane, then the 787-9 is the obvious choice, with great profitability as well.
