HKG/VHHH - Hong Kong
The complete, player curated guide, for HKG
Edited by: @Hirohitoswaifu , @Thatflyerguy , @carlsberg72, @CJ_RVWilliams
Current as of WoA 3.4.0
:warning: PLEASE READ: Since this airport has just been released and is on the large side, it will take a while to get the page up and running and to the correct standards. Please be patient, construction in progress :slightly_smiling_face:.
Hong Kong International Airport/Chek Lap Kok International Airport
(IATA: HKG / ICAO: VHHH)
(Space for photos)
General Info:
Hong Kong International Airport, or as it is known in some circles Chek Lap Kok International Airport to distinguish it from the old Hong Kong Airport Kai Tak which it replaced in 1998, is the only airport for the territory of Hong Kong and is situated to the west of the region comprising of excavated land around the island of Chek Lap Kok in the New Territories.
The initial planning for a new airport due to the severe overcrowding of Kai Tak was planned in 1974, where Chek Lap Kok was identified as good spot as it would allow for multiple runways and round the clock operations being situated away from the population centres around Kowloon Bay. In 1982 plans and engineering studies were conducted but they were shelved in 1983 due to the high economic and development costs and also due to pressure from the British Government which was cutting back due to the recession. In 1989 the plans were brought back out and studies were undertaken again for the Chek Lap Kok site as well as a close one between Hong Kong Island and Lantau and just maintaining the current Kai Tak. In October 1989, the current plan was chosen and announced by the governor and work began in 1991, with the airport opening in July 1998.
The airport as of 2010 is the worlds busiest for goods traffic and in 2015 it was the 4th busiest in the world for international passenger traffic, with 68 million passengers transiting the airport. Its busiest year was 2018 with 74.6 million passengers whereas last year due to the fallout of the pandemic in 2020, the airport had 53 million passengers. This is likely to increase massively with the opening of the new terminal 2.
Unlock requirement: reach level 72 at SCL or 22 Gold Planes
Airport Overview
The airport features 3 operational parallel runways with 07L, 07C and 07R. In a future update runways 25L, 25C & 25R will be operational depending on real METAR data.
07L
07C
07R
25L
25C
25R
Max Available Stands:
258 Passenger
78 Cargo
Start with 4 ABC stands in Terminal 1
D309L, D309R, D310L, D310R
Stand Information
Terminal 1
Terminal 1
Terminal Type Size Available Cost Numbers Notes
T1 Pax ABC 4 0 D309L/R - D310 L/R Provided for Free
T1 Pax ABC 14 168,000 D301L/R - D308 L/R D303 L/R do not exist, block D301-D309 if used
T1 Pax DEF 10 300,000 D301 - D310 Blocks L/R stands if used. D303 is standalone
T1 Pax ABCDEF 9 378,000 D310 - D319
Total T1 37 846,000
Terminal 1A
Terminal 1A
T1A Extension 25,000 Terminal Purchase
T1A Pax ABCDEF 2 84,000 S11 & S23 Only ABCDEF gates in Terminal
T1A Pax ABC 6 72,000 S25R - S35R Blocks DEF stands if used
T1A Pax ABC 8 96,000 N10/12 N24R - N34R 24R-34R block DE Stands if used
T1A Pax DEF 6 180,000 S25 - S35 Blocks R stands if used
T1A Pax DE 2 36,000 N24 & N34 No F here, so be careful blocks R Stands if used
T1A Pax DEF 4 120,000 N26 - N32 Blocks R Stands if used
Total T1A 28 613,000
Terminal 1B
Terminal 1B
T1B Extension 12,000 Terminal Purchase
T1B Pax ABCDEF 3 126,000 N5, N8-N9 Only ABCDEF gates in Terminal
T1B Pax ABC 2 24,000 N6R - N7R Blocks DEF stands if used
T1B Pax DEF 2 60,000 N6 - N7 Blocks R stands if used
Total T1B 7 222,000
Terminal 1C
Terminal 1C
T1C Extension 10,000 Terminal Purchase
T1C Pax ABCDEF 1 42,000 S4 Only ABCDEF gate in Terminal
T1C Pax ABC 3 36,000 S1R - S3R Blocks DEF stands if used
T1C Pax DEF 3 90,000 S1 - S3 Blocks R stands if used
Total T1C 7 178,000
Terminal1D
Terminal 1D
T1D Extension 23,000 Terminal Purchase
T1D Pax ABCDE 3 90,000 N141 - N142 & N144 Hard Stands
T1D Pax AB 1 6,000 R16 Main Terminal
T1D Pax ABC 8 96,000 R13 - R15 & R17-21 Main Terminal
T1D Pax ABCD 1 20,000 N143 Hard Stand
T1D Pax ABC 1 12,000 N145 Blocks R stands if used
Total T1D 14 247,000
Terminal 1E
Terminal 1E
T1E Extension 20,000 Terminal Purchase
T1E Pax ABCDEF 6 252,000 S101 - S106 Hard Stands
T1E Pax ABCDE 4 120,000 S107/S108, S110/S111 Hard Stands
T1E Pax ABC 1 12,000 S109 Hard Stand
Total T1E 11 404,000
Terminal 1F
Terminal 1F
T1F Extension 23,000 Terminal Purchase
T1F Pax DEF 4 120,000 N60 - N66 Blocks R Stands if Used
T1F Pax ABC 6 72,000 N60R - N70R Blocks DEF Stands if Used
T1F Pax D 2 16,000 N68 & N70 Blocked by R Stands if Used
T1F Pax DEF 6 180,000 W61 - W71 Blocks R Stands if Used
T1F Pax ABCDEF 1 42,000 N36 Only ABCDEF stand in Terminal
T1F Pax ABC 6 72,000 W61R - W71R Blocks DEF Stands if Used
Total T1F 25 525,000
Terminal 1G
Terminal 1G
T1G Extension 21,000 Terminal Purchase
T1G Pax DEF 5 150,000 W40 - W48 Blocks R Stands if Used
T1G Pax ABC 5 60,000 W40R - W48R Blocks DEF Stands if Used
T1G Pax DEF 5 150,000 S41 - S49 Blocks R Stands if Used
T1G Pax ABCDEF 1 42,000 W50 Only ABCDEF stand in Terminal
T1G Pax ABC 5 60,000 S41R - S49R Blocks DEF Stands if Used
Total T1G 21 483,000
Terminal 1H
Terminal 1H
T1H Extension 15,000 Terminal Purchase
T1H Pax DEF 5 150,000 W121 - W125 Blocks L/R Stands if Used
T1H Pax ABC 7 84,000 W121 L - W125R Blocks DEF Stands if Used
Total T1H 12 249,000
Terminal 1I
Terminal 1I
T1I Extension 30,000 Terminal Purchase
T1I Pax ABCDEF 19 798,000 D201 - D219 Blocks L/R Stands if Used
Total T1I 19 828,000
T1 Summary
T1 - Summary
Terminal Available Cost
T1 37 846,000
T1A 28 613,000
T1B 7 222,000
T1C 7 178,000
T1D 14 247,000
T1E 11 404,000
T1F 25 525,000
T1G 21 483,000
T1H 12 249,000
T1I 19 828,000
Total 181 4,595,000
Terminal 2
Terminal 2
Terminal 2
T2 Purchase 40,000 Terminal Purchase
T2 Pax ABCDEF 6 252,000 Y19-Y22, Y43-Y44 Left side on normal unrotated view
T2 Pax ABCDEF 4 168,000 Y2-Y3, Y52-Y53 Right side on normal unrotated view
T2 Pax ABCD 1 20,000 Y1
Total T2 11 480,000
Terminal 2A
Terminal 2A
T2A Extension 27,000 Terminal Purchase
T2A Pax ABCDEF 4 168,000 Y4-Y7 Lower side of Triangle on normal unrotated view
T2A Pax ABCDEF 5 210,000 Y23-Y27 Left side of Triangle on normal unrotated view
T2A Pax ABCD 7 140,000 Y36-Y42
Total T2A 16 545,000
Terminal 2B
Terminal 2B
T2B Extension 27,000 Terminal Purchase
T2B Pax ABCDEF 4 168,000 Y54-Y57 Right side of Triangle on normal unrotated view
T2B Pax ABCDEF 5 210,000 Y45-Y49 Left side of Triangle on normal unrotated view
T2B Pax ABCD 7 140,000 Y61-Y67 Bottom Side of Triangle
Total T2B 16 545,000
Terminal 2C
Terminal 2C
T2C Extension 18,000 Terminal Purchase
T2C Pax ABCDEF 5 210,000 Y33-Y35, Y50-Y51 Bottom Hard Stands on normal view
T2C Pax ABCDEF 5 210,000 Y28-Y32 Top Hard Stands on normal view
Total T2C 10 438,000
Terminal 2D
Terminal 2D
T2D Extension 20,000 Terminal Purchase
T2D Pax ABCDEF 1 42,000 Y8 Top Hard Stands on normal view
T2D Pax ABCDE 2 60,000 Y9-Y10 Top Hard Stands on normal view
T2D Pax ABCD 3 60,000 Y13-Y15 Middle Hard Stands on normal view
T2D Pax ABCDE 5 150,000 Y11-Y12,Y16-Y18 Middle Hard Stands on normal view
T2D Pax ABCDE 2 60,000 Y58-Y59 Bottom Hard Stands on normal view
T2D Pax ABCDEF 1 42,000 Y60 Bottom Hard Stands on normal view
Total T2D 14 434,000
Terminal 2E
Terminal 2E
T2E Extension 18,000 Terminal Purchase
T2E Pax ABCDEF 5 210,000 Y68-Y72 Left Hard Stands on normal view
T2E Pax ABCDEF 5 210,000 Y73-Y77 Left Hard Stands on normal view
Total T2E 10 438,000
Terminal 2 Summary
Terminal 2 Summary
T2 11 480,000
T2A 16 545,000
T2B 16 545,000
T2C 10 438,000
T2D 14 434,000
T2E 10 438,000
Total 77 2,880,000 7,481,000
Stand Type Summary
Pax Stand Type Summary
Stand Type Available Cost
AB 1 6,000
ABC 76 864,000
ABCD 19 380,000
ABCDE 16 480,000
ABCDEF 92 3,864,000
D 2 16,000
DE 2 36,000
DEF 50 1,500,000
Total 258 7,146,000
Purchases - 329,000
Grand Total 7,475,000
Pax Stands by Max Aircraft Size
# of Stands by Max Aircraft Size
Max Stand Available Cost
B 1 6,000
C 76 864,000
D 21 396,000
E 18 516,000
F 142 5,364,000
Total 258 7,146,000
Cargo
Cargo A
Cargo A
A Purchase 28,000 Terminal Purchase
A Cargo ABCDEF 4 168,000 X11-X14 Main Building
A Cargo ABC 6 72,000 X7L/R, X8L, X9R, X10L/R Main Building, block DE or DEF gates when in use
A Cargo DE 2 36,000 X8-X9 Main Building - Block X9R or X8L when in use
A Cargo DEF 2 60,000 Y2-Y3, Y52-Y53 Main Building
A Cargo ABCDEF 1 42,000 X35 Hard Stand
A Cargo DEFG 1 44,000 X33 Satellite - Blocks X33R when in use
A Cargo DEF 1 30,000 X34 Satellite Blocks X34L when in Use
A Cargo ABC 3 36,000 X33L/R, X34L Satellite, X33R and X34L block DEF Stands
Total Cargo A 20 516,000
Cargo B
Cargo B
B Extension 20,000 Terminal Purchase
B Cargo ABCDEF 9 378,000 X15-Z23 Lower side of Triangle on normal unrotated view
Total Cargo B 9 398,000
Cargo C
Cargo C
C Extension 15,000 Terminal Purchase
C Cargo ABCD 6 120,000 X1-X6
Total Cargo C 6 135,000
Cargo D
Cargo D
D Extension 18,000 Terminal Purchase
D Cargo ABCDEF 8 336,000 X24-X31
Total Cargo D 8 354,000
Cargo E
Cargo E
E Cargo ABCDEF 2 84,000 D327-D328 Top Hard Stands on normal view
E Cargo ABCDE 3 90,000 L434-L435, X458 Top Hard Stands on normal view
E Cargo ABC 4 48,000 L431-L433, X459 Middle Hard Stands on normal view
Total Cargo E 9 242,000
Cargo F
Cargo F
F Extension 25,000 Terminal Purchase
F Cargo ABCDEF 13 546,000 L421-L427, X451-X456
Total Cargo F 13 571,000
Cargo G
Cargo G
G Extension 25,000 Terminal Purchase
G Cargo ABCDEF 13 546,000 Y8 Top Hard Stands on normal view
Total Cargo G 13 571,000
Cargo Terminal
Terminal Summary
Cargo Available Cost
A 20 516,000
B 9 398,000
C 6 135,000
D 8 354,000
E 9 242,000
F 13 571,000
G 13 571,000
Total 78 2,787,000
Stand Type
Stand Type
Cargo Stand Available Cost
ABC 13 156,000
ABCD 6 120,000
ABCDE 3 90,000
ABCDEF 50 2,100,000
DE 2 36,000
DEF 3 90,000
DEFG 1 44,000
Total 78 2,636,000
Purchases - 151,000
Grand Total 78 2,787,000
Stand Size
Stand Size
C 13 156,000
D 6 120,000
E 5 126,000
F 53 2,190,000
G 1 44,000
Total 78 2,636,000
Total Airport
Terminal Summary
Terminal Summary
Terminal Summary Available Cost
T1 181 4,595,000
T2 77 2,880,000
Pax 258 7,475,000
Cargo 78 2,787,000
Total 336 10,262,000
Stand Type
Stand Type
Summary Stand Type Available Cost
AB 1 6,000
ABC 90 1,032,000
ABCD 25 500,000
ABCDE 19 570,000
ABCDEF 142 5,964,000
D 2 16,000
DE 4 72,000
DEF 53 1,590,000
DEFG 1 44,000
Total 336 9,788,000
Purchases - 480,000
Grand Total 336 10,262,000
Max Stand
Max Stand
Summary Max Stand Available Cost
B 1 6,000
C 89 1,020,000
D 27 516,000
E 23 642,000
F 195 7,554,000
G 1 44,000
Total 336 9,782,000
Aircraft categories and expected arrivals
A and B planes: There are no local DHC-6s, which are the only A-class aircraft. You will find some B-class planes, none local, with both cargo and pax aircraft available from a host of different destinations across China, Indonesia, Japan, Laos, Thailand and Vietnam (With the BA E170 being available from Singapore). The aircraft available are ATR’s and COMAC’s, both of which come in pax and freighter form, with E170’s, CRJ 700’s available from Japan’s Ibex and Fuji Dream as well as ATR’s and the Saab 340 available from JAL.
C and D planes: Local contracts exist in both C class pax aircraft and D class cargo aircraft with C class options from Cathay with the A21NX, Greater Bay with the B738, HK Express with the A320/321/20N/21NX and HongKong Airlines with the 320/321. D class locals are air Hongkong with their A300F and UPS with their A300F/752F & 763F. A host of regional C & D class pax & cargo aircraft are available with even more internationally.
E, F, and G planes:
Local contracts:
Cargo- all cargo planes can land at this airport.
(More pictures)
Airport notes
Start with 10,000 W’s
Handlers
Handler Build Up
Handlers Available
Start 40
T1 186
T2 83
Cargo 85
Levels 20
Total Basic 414
Premium Pass 20
Total Premium 434
  • Does not include any personally purchased for GP etc.
Contracts
Note: these are the total number of contracts you can get without buying any, you are given 3 at the start to get you going.
Contracts Build up
Contracts Available
Start 25
T1 186
T2 83
Cargo 85
Levels 20
Total Basic 399
Premium Pass 20
Total Premium 419
Equipment
Equipment Build up
Note: you only get 75 cargo and that has to cover large Pax and all Cargo aircraft.
Equipment Available Provided Purchase Cost Total Cost
Boarding 135 1 134 2500 335,000
Baggage 135 1 134 1500 201,000
Cleaning 135 1 134 1500 201,000
Cargo 75 1 74 2000 148,000
Catering 135 1 134 2000 268,000
Fuel 135 1 134 3500 469,000
Lavatory 135 1 134 1500 201,000
Water 135 1 134 1500 201,000
Ambulift 135 1 134 3000 402,000
Repair 135 1 134 2000 268,000
Total 1,290 10 1,280 21,000 2,694,000
Limitations
Not sure there are any. It’ll take a while to build the airport up but that’s part of the fun. Long taxi times for some of the gates, both for arriving and departing flights. Queues can quickly form if takeoffs aren’t being handled quickly, though there is a lot of taxiway before any repercussions occur.
Levels
There are 90 levels at HKG, the Premium Pass for this airport is 80GP.
Reaching level - unlocks -
W’s - 255,000
Generic Aircraft - 24
Player Aircraft - 12
Silver Planes - 31,000
Liveries - 1
Handlers - 20
Contracts - 20
GP - 4
Airport Stars - 2 and 3
Premium Pass
W’s - 250,000
Generic Aircraft - 0
Player Aircraft - 42
Liveries - 3
Handlers - 20
Contracts - 20
The level unlocks are Regional - 28 & International - 44
The airport unlock for the next airport will likely be level 91, though as per a few previous airports, there may be some levels added.
Connectivity (for player planes)
Player Strategies
@CJ_RVWilliams (based on experience at release 3.4.0) – Immediately unlock the cargo terminal from the get go. Many AI contracts from the local contracts roll will be A306Fs and B752Fs. These are incredibly useful for early XP gains. From there, keep buying terminals and stands, trying to keep your stands equally dispersed between the three terminals and their respective runways (avoid the south section of terminal T1 at first). Make liberal use the stand blocking mechanic. There are a lot of stands that overlap where F planes will reduce neighboring stand’s capacity to a D plane.
