Continuing the discussion from How to create connections in 2.0:
All player connections in this format are set for 10 trips required for completion. You will only receive Silver Planes and XP after 10 trips. You will receive Wollars for each successful handling.
Hey but the random connection cancels after one trip only. What to do???
Random connections are deliberately designed to be a single handling. So if you want to try and connect with that person, make a note of their user and then try to connect using the option noted in the how to. The old random dice system was not working well, so it was removed in V2 and replaced with the current way.
