Hi, thanks for the welcome.
So, as I work in the morning, I’m stuck in the afternoon, around 4 PM, UTC -3.
However, on weekends I can play all day, no problem.
That’s good, I can work with that, I’ll just send them for your evening then!
Similar times for me to be honest (other than the 3 hour difference)
Hello again.
Do you opened your PRG airport?
I just opened my Bri airport.
Yes, I have. I thought I got a notification saying you’d requested, but when I went it to the game it wasn’t there.
Feel free to add me
OK I’m going to service now.
When I get back, I’ll add you by my INN airport.
Thank you so much again.
@liquidaura51 looks like your request is already fulfilled.
@kryll looks like your request is already fulfilled.
@Kayls looks like your request is already fulfilled.
I would assume that as they literally had someone reply saying they would do it
That’s great, but I thought the whole point of this thread was that any requests fulfilled will be deleted (either by posted or by moderator, when it’s obvious to them) so that only open requests are retained - to avoid the clutter in the thread. I was just making it plain and obvious in case if it was any less obvious, for moderators (or the poster) to take the cue.
Good morning and belated Christmas everyone.
I am currently playing INN after a very LONG break and catching up with everything. As this thread says, searching for a solid connection between INN-BRI.
Username: grex0920
Timezone: UTC or GMT (London, UK)
Play times: I do regularly check everyday couple times a day. So I am able to visit and send back planes quite often.
Kind regards.
Looking for connection
Username: marechkon33 feel free to add
UTC-8
Nerf connection
User. Pedrojpf
Time. GMT 0 (lisbon, london) time
Can connect with prague too
add you my BRI to your INN
Looking for connection, my INN to your BRI
Username: winneror , feel free to add
UTC +8
also can connect with PRG
“Olá, preciso de conexões entre BRI-LEJ / BRI-INN.
Jogo várias vezes ao dia
NICK: llucas0a
GMT -3”
“Hola, necesito conexiones entre BRI-LEJ / BRI-INN. juego varias veces al dia
NICO: llucas0a
GMT-3”
“Hello, I need connections between BRI-LEJ / BRI-INN. I play several times a day
USER: llucas0a
GMT-3”
Fala @llucas0a , ainda precisando de conexão???
Se sim, responde aqui.
Tô precisando agora para BRI-PRG. As demais consegui com outros jogadores m
@llucas0a
Do seu BRI para PRG???
Temos um grupo de Whatsapp.
Me manda msg privado caso queira entrar no grupo.
@Krolyn, Is it from your INN to my BRI? If yes, I can make the connection anytime. GMT -4 Username: ShadowSTH
