More fun airport
What is the best and most fun airport?
Sigh… This again :man_facepalming:…
Im going to give my honest opinion on what airports i will go and which i would avoid.
The airport i avoid to buy are
  • SXM: By far the worst airport in the game, 8 C aircraft stands, 3 cargo stands (2 up to C and 1 F), 5 E stands, 1 F stand very slow to grind because of the amount of A aircraft and the worst aircraft taxi movements in the game (especially E) which takes a whole 2-3 minutes when an aircraft to arrive and up to 2 minutes on departure. Sure there is good scenery but the cons outweigh the pros.
  • CNN: An ok airport but lack of D stands (especially Cargo) but its, the D aircraft movemets aren’t great but when they departure from Runway 25 they are much better and good amount of C aircraft stands
The 2 airports i am going to recommend as they are large airport and has 3 runways.
  • BKK: A nice 3 runway layout (3 Arrivals and 2 takeoffs) when you have a lot of D, E and F aircraft you can easily make 100K wollars each gameplay (if you play for an Hour), dose not have large amount of cargo stands but it still has a great amount (over 20 Cargo stands)
  • HKG: Same as BKK but much larger (all runways can be used for Arrivals and departures) and has more cargo stands.
    (Moraless the same as BKK so i won’t be going any further)
Personally all airports (except SXM) are great airports to play depending on my mood of the day.
Ps. Please don’t chase me after saying SXM is a bad airport because although i don’t like it the scenery is definitely spot on!
Best: HKG
Most fun: depends
Check this for more:
