[Other] - Strobe lights turn on when cleared to line up for departure
Turn on strobe lights when an aircraft is cleared to enter the runway for departure.
When the aircraft receives the “Line up” command, the strobe lights would automatically turn on. Currently, they only activate during takeoff roll, but in real life, strobes are turned on when entering an active runway.
In real life, pilots turn on their strobe lights when crossing ( [Other] Strobe Lights Turn on When Crossing Active Runways ) or entering an active runway. This improves realism and helps simulate proper aviation procedures.
In most WOA airports, this detail may go unnoticed, except for airports like INN where the aircraft must taxi to the end of the runway and make a 180° turn. However, even during this movement on the active runway, strobe lights remain off.
ScreenRecording_06-03-2025 10-13-02_1-2
ScreenRecording_06-03-2025 10-19-11_1
Seconded
I might also add that strobe lights should stay on until the aircraft has fully vacated the runway, not at the moment when it has just slowed down and is moving toward the taxiway to exit.
Right now in the game, they turn off too early, while the aircraft is still on the runway.
The “Clear to land” button and the arrival queue should only appear after the previous aircraft has fully left the runway and turned off its strobes.
That’s only if going deep into the details.
This detail is up to the developers’ discretion and whether it’s possible to implement. :slightly_smiling_face:
Thank you for your feedback! We’ve created a task for it. The strobe lights will turn on when the aircraft reaches the line-up trigger and turn off after it leaves the runway.
Another small detail but would really add to the realism for aviation fans is that in real-world aviation, strobe lights are activated whenever an aircraft enters or crosses an active runway — not just during takeoff or landing. I’d like to suggest that aircraft in WoA also turn on their strobes when crossing runways during taxi operations, to better reflect realistic procedures and enhance immersion.
They already do this, I’ve noticed atleast at GRU
I’m still hoping they add that the strobe lights come on the moment the aircraft enter the runway when they’re cleared to line up and wait
I’m wondering if this will still be implemented?
Planes still line up (backtrack in the case of SXM and INN) but the strobe lights are still off, they should turn on as soon as line up clearance is given
This would be great! I have a few more ideas: [Other] - Strobe Lights and Runways
Will it be possible to implement this feature?
Now, along with INN, we also have CNN, where this function would be noticeable as well — when we clear the aircraft to line up for departure, the strobes are already active during this time.
Thanks in advance for considering this proposal.
Hello again! I’m just checking to see if this is still going to be implemented.
Can I add that they should be a bit brighter as well. Playing at night, when looking from the tower sometimes you can hardly see them unless you zoom in. To make it more realistic, make them brighter to be seen.
