BRI: Bari
The complete, player curated guide, for BRI - v2.0.2 [Update in Progress]
Written by: @Ivan0921
Edited by: @tako18126 @AviaWilliam @SainsburysVan @Techestro @carlsberg72 @Thatflyerguy
Bari Karol Wojtyła Airport / Bari Palese
(IATA: BRI, ICAO: LIBD)
General Info: LIBD (BRI) or Bari Airport is located in the south-east of the Italian peninsula. It is the second airport that you will unlock in WoA. It can service up to 25 S, M, and L aircraft in-game. Click / Tap Here to see Bari Airport in Google Maps.
Unlock Requirements: Unlocking BRI either completing level 27 at INN or 4GP
Tip: Click on the Arrow (⯈) to read about the respective topic.
Key: RWY = Runway; [S] = Small; [M] = Medium; [L] = Large; [S/M] = Small & Medium; ₩ = WoA Money; GP = Golden Airplane, SP = Silver Planes
Airport Overview:
In-game there is 1 runway and 1 taxiway with multiple exits. RWY25 is the active one. Aircraft land and take off on RWY25 and take the nearest exit depending on plane size. There are a total of 21 Commercial stands and 4 Cargo Stands.
This is a focused aerial view of the airport. In the picture, you can see everything important and all of the stands. You can see the taxiway that connects the departing planes to the runway from the stands. To the top right is the Cargo Stands while the rest are Commercial Stands. To the left on the apron are some non-accessible stands.
See Stands & Costs for a more detailed overview of Stands!
[details =Camera Views
There are 5 Camera Views
General Overhead (this is the default view)
Terminal Side View
Apron View
Runway Landing View
Plane Spotting View*
[/details
Accepted Airplane Categories:
  • Commercial Aircrafts: S; M; L
  • Cargo Aircrafts: S; M
Aircraft Handling
  • Aircraft Handlers - These are needed for the successful On-Time handling of aircraft. At INN you start with X total and it’s up to you how you allocate them. However for smaller aircraft you usually need the total number for that aircraft to have an on-time departure.
    With BRI you only have a choice of S or M cargo aircraft and those will need between 2 and 7 handlers. Hint: when you have M cargo, you generally can use less handlers than you would for pax aircraft meaning your total will go further. If needed you can also use the Automatic Handler option for ₩ and the aircraft will process for you. But it will cost you one of you available handlers too.
For Passenger Aircraft: you have a choice of S, M and L which can require from 2 to 13 handlers.
You can gain 12 more handlers total by completing levels: 2, 19, 28 and 44 you can also buy them in the shop as shown below.
Aircraft Movement:
  • Landing: Aircrafts land on RWY 25, then taxi to the gate. Planes dependent on size would take the nearest exit and entry to their stand. In the focus view, the first taxiway is for L planes, moving to the left is for M planes, and before that is the S planes. The Stands are divided into 3 Apron Areas since there are 3 taxiways. Planes for 3xx - 4xx would taxi-in from the first taxiway on the right and taxi-out from the middle one. Planes for 205 would use the middle taxiway for both. Planes for 201 and 1xx would use the left taxiway for both.
  • Departure Holding Positions: Aircraft will hold short at the holding position on RWY 25 taxiway for take-off.
  • Take-off: Aircraft will taxi to RWY 25 onto the runway and take-off.
However, this airport sometimes has drawbacks in terms of Aircraft Movement, see Limitations for more info.
Limitations:
  • Continuous play over time backs up traffic at the airport and leaves most stands empty. Continuous play is not recommended. The airport can only have 1 airplane taxiing at the same time from parking stands. A plane pushing back from a terminal stand the movement of many taxiing planes. Takeoff queues are frequent, along with landing queues. Bulk play is recommended.
    Constantly manage the takeoff/landing ratio according to your airport’s situation.
Stands & Costs:
When starting at this Airport, you get 2 [S] Stands.
  1. No. of Stands:
  • 2 [S] Commercial Stands - Gate: 402; 405
  • 6 [S/M] Commercial Stands (jetway capable) - Gate: 302; 304; 305; 307; 309; 311
  • 2 [L] Commercial Stands - Gate: 201; 205
  • 11 [S/M] Commercial Stands - Gate: 101 - 105; 107; 301; 303; 306; 308; 310
  • 4 [S/M] Cargo Stands - Gate: 401; 403; 404,406
  1. Cost for Additional Stands:
  • 5 000 ₩ for [S] Stands.
  • 10 000 ₩ for [M] Stands.
  • 15 000 ₩ for [L] Stands.
  • 5 000 ₩ for [S] Cargo Stands.
  • 10 000 ₩ for [M] Crago Stand.
Total Cost to buy all Stands: (S) 105 000 ₩, (M) 210,000 ₩, (L) 30,000 ₩
Total: 345,000 ₩
Buildings & Cost:
To handle bigger / more planes, you need to unlock specific buildings.
  1. Terminal Building
  • Cost: 15 000 ₩
  • Unlocks: 6 [S/M] Stands
Total Cost to buy all Buildings: 15 000 ₩
Achievements:
  1. Common Achievements: These are basically the same at all airports.
  • Contracts for Generic aircraft - Using the contracts menu or via level rewards or events. Handle the required number of flights to achieve rewards. More in a separate post.
  • Player & Airport Connections Handle 10 flights between WOA airports and a specific player to earn Silver Planes and XP to level up. Amounts vary based on plane and location. More on this in a separate contracts post.
  1. BRI Specific: These are only available in BRI
  • Unlock BRI Complete level 27 at INN Reward: Unlock [BRI]
(upload://49hjQk5AIZgPSAoQU1MbhIw56uO.jpeg)
Levels:
This airport has currently 44 Levels (as of September 6th 2023). The Level rewards may change (kinda) frequently. Please Check in-game for up-to-date rewards for each Level. However the screen shots below are the rewards at time of writing.
There are 2 tracks. The upper track everyone has access to. The Premium Pass lower track is available for 20GP. You can buy it at any time during your game play and all the rewards for any levels completed will be made available to you to claim
Total Level Rewards:
Regular:
Contract aircraft : 7, 82,000 W, Aircraft Handlers : 12, Silver Planes: 6,300, Own Aircraft: 5, Aircraft Liveries: 1, Gold Planes : 3, Additional Contracts : 9, Additional Stars : 2, Unlock : PRG
Premium Pass: 20 GP (in addition to regular above)
Contract aircraft :
82,000 W, Aircraft Handlers : 12, Silver Planes: 6,300, Own Aircraft: 15, Aircraft Liveries: 5, Additional Contracts : 9
Connectivity:
*^ Some Destinations handle Only [S] or Only [M] or Only [L] or Only Cargo or a mix of [S/M/L] & Cargo etc.
Player Strategies
@AviaWilliam suggests: While at INN save one (1) Golden Plane and exchange it for 10,000 ₩. At BRI buy advanced handling and buy one M stand and upgrade Service trucks to LVL 2 each buy another bus and fuel truck and you’re ready for Bari!
@tako18126 suggests: Once service trucks are upgraded focus on purchasing stands that are NOT connected to the terminals. Invest in the M stands that are not connected to the terminal. Cargo is also key, make sure to purchase the cargo stand before as well.
@Ivan0921 suggests: use of gold planes to speed up early ramp-up of operations is suggested. I advise having 4-5 S stands so you can quickly get the BAe achievement. Focus on the immediate development of the 4 M stands, followed by L, then terminal and its M stands, and finally, S Cargo and other S stands. Aim to have all stands bought. Do not forget to upgrade vehicles for maximum grind efficiency.
@Thatflyerguy suggests: go one level past unlocking BRI at INN, then get but DO NOT CLAIM the DH8D. It does not have an airport tag which means you can claim it anywhere. Claim at BRI and sell for a hefty starting boost
Final thoughts & Additional Notes
BRI is an excellent airport to introduce beginners to the fuller potential of the game because as was mentioned INN is inherently difficult for grinding cash. It also serves, in my opinion, as the best airport for learning how to build and use your own fleet. Once upgraded fully (both stands and services) and along with a strong fleet, BRI can also become a good airport for farming golden planes while you’re chasing connections and achievements.
Share your Experiences at BRI at BRI Sharepoint!
We hope you enjoyed reading and more importantly found this useful in your progression through WoA. :slight_smile:
Have a nice Flight! :airplane:
~ Ivan, along with Tako, Avia, Jamster, Thatflyerguy, and Techestro
Graphic Styles & Imaging used with permission from WoA.
